SSD Not showing up in bios but is visible inside windows
Hi there.
I have an Asus R416S laptop on which there is zero information on the internet.
It was working super slow, so I decided to format the SSD (https://www.partitionwizard.com/partitio...) and have a clean Windows 10 installation.
After formatting the SSD, wh.en selecting the hard drive, windows shows an error: (https://www.partitionwizard.com/partitio...)
Alright. I go into BIOS but under BOOT, the SSD doesn't show up. I can only see my bootable Windows USB which is set to Boot Priority #1.
If the SSD is disabled, I can't enable the drive because the bios is SO bare bones that I can't Change SATA Controller Mode as there is no option like that in the BIOS. Resetting the BIOS to default of optimised settings also didn't make the SSD appear.
I created a portable windows installation on an USB and booting windows through the USB, I can see the SSD in Windows. I can copy to it and open whatever I have copied on it.
I thought it might be a firmware problem.. Downloaded new and old SanDisk SSD tools and the SSD Dashboard but those didn't recognize the SSD.
At this point I am stumped. Does anyone have any ideas what could I do?
3条评论
Hi @tomekks ,
Are you sure that it mightn't be this one? It might be worth a look at the specs to see if they are similar to the specs in yours.
Select the OS to find firmware download etc
由 jayeff 完成的
You are correct, that is the one.
This is the SSD that's attached to the MB: https://eu.mouser.com/ProductDetail/SanD...
The only possible solutions I see now, is to get a special USB from Asus as the BIOS can't be updated. I am really stumped.. :/
由 Toms 完成的
Here are photos of BIOS to get a better understanding: https://photos.app.goo.gl/sRwWn9qy3oHW9A...
由 Toms 完成的
