跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6s backlight pins
Hello. I wish to find out which two from the four pins from the LED backlight actually use 16v. Which is plus and which is minus? I have a backlight issue that it's to expensive to repair around here and need a cheaper solution. Unorthodox maybe, but this doesn't involve motherboard soldering.
Update (02/08/2018)
Thanks. I figured it out. Since they are LEDs... They don't get burned when the polarity is wrong. So I found out that the first and the third contacts, starting from upper side, were those I wanted. Again, I didn't pay attention to polarity. It worked. If it didn't, then I just needed to solder the wires the other way. I have tested with a 16v transformer from a printer and from an iPhone 4 and 6. iPhone 4 would only power up half of the LEDs. But you MUST have it already connected, or else it will only send juice for a fraction of a second. Tested on my tongue and with a power meter. It's good that it's only a jolt, so it won't blow up it's filter or whatever it has before the LCD connector. Was fun. Now I have 2 apples on a branch lmao.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I am not really certain what exactly you are asking; will you be trying to directly power the backlight?
The backlight circuit is one anode (driving the ~16V) and two cathodes (return paths). That is what the circuit on the logic board looks like. If you are trying to connect directly to the soldered flex connector on the display, they tend to vary from one supplier to the next. One trick is to use a 9V battery or a DCPS and power the backlight directly to see what is what.
If this doesn't answer your question, get back to me with more details and/or pictures.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Alexandru Sirb 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,065
