跳转到主内容
Repair guides and information for the HP 250 G3, a budget laptop released by HP in 2014.
Why is my pc not turning on
it turns on and shows the blue screen loading with the attempt to go where i usually put my password but keeps on saying diagnosing
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi
If you have Win 10 installed (you haven't said what OS is installed) try entering the WRE (Windows Recovery Environment) menu.
To do this, turn on the laptop and when it boots into Windows, force stop the laptop by holding the Power button until it shuts down.
Do this 3 times, i.e. Power on > boot > force stop > power on > boot > force stop etc.
On the 3rd attempt it should boot into the WRE.
Select troubleshooting > advanced > Startup repair and follow the prompts.
If this doesn't work use the same procedure as before to get into WRE and select either the system restore point option or the system image option (if you have them that is)
DO NOT select the Reset this PC option as this will erase all your data and reinstall Windows.
If you can't get into WRE for whatever reason, you can create a Win 10 recovery USB from any known working Win 10 PC. You'll need an 8GB USB flashdrive and about 60 minutes of time to create it. Go to Control Panel > Recovery and find the create USB recovery drive link - You should make one yourself when your laptop is working and keep it safe in case of future problems.
When you have the Recovery USB drive, insert it into your laptop and then when you start the laptop press F9 to select the USB drive as the first boot option and then restart the laptop . If it doesn't boot from the USB go into BIOS and enable Legacy USB function in the settings.
这个答案有帮助吗?
得分 2
添加一条评论
if its not log in your os is down.
if reseting your ram is down.
if more details you have shoot for better help?!!!
这个答案有帮助吗?
得分 0
添加一条评论
hi
try to clean ram and reinstall windows
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mpgumzi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 759
