跳转到主内容
加入维修社区 - 创建账户
一部由小米在2015年1月份发布的智能手机,配备了5.7英寸屏幕和1300万像素相机。
My battery won't charge, it only shows its charging for 1 second
Hi,
My Xiaomi Mi Max recently stopped charging. It now only stays alive on a charger. It won't charge when its turned off and on the charging even though the charging light is on, on the phone. When the phone is turned on it shows for 1 second its charging but then switches to connect charger even though the charger is connected, and it only stays alive and does not charge. Please help me out guys.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
I have the same problem
完成的
添加一条评论
4个答案
Sounds like your battery is literally dead!
Xiaomi Mi Note Battery Replacement
这个答案有帮助吗?
得分 0
17条评论:
I'd say that too but the weird thing is I had this problem like 2 weeks ago as well, and then suddenly it started working again.. :p Any idea why?
完成的
did you ever drop it in water?
完成的
No I never did
完成的
Sometimes when you have your charger plugged in against a bed or something for a long time, the cords can get stretched. You will either have to get a new charger, or try plugging the phone in and leaving it in a specific position.
完成的
Doesn't work I've tried a lot of different chargers.
完成的
显示更多的12条评论
添加一条评论
You need a new charger.
If you try another charger and it doesn't work, your charging panel may need replaced.
这个答案有帮助吗?
得分 0
6条评论:
Right but then why did my phone started working after having this problem before?
完成的
What do you mean you had it before? What happened the first time?
完成的
Basically the same situation happened but suddenly it started working again and now 2 weeks later I'm back to this issue.
完成的
Are you able to send a picture of the charging panel? The place on the phone where you put the cable, if you don't already know that.
完成的
Basically just looking normal man, like a normal charging port.
完成的
显示更多的1条评论
添加一条评论
1.use a safety pin and clean the debris from the port
2.open back panel and unscrew bottom part and then clean the pins of usb board
3.replace with a new usdb port panel
这个答案有帮助吗?
得分 0
添加一条评论
my xiaomi device Charge very slow like in 1hour only5 percent charged
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jan Jansen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 31
总计 13,293
