跳转到主内容
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
20 个问题 查看全部
bypassing settingslocked password after factory reset
I factory reset my viking 2 tablet model number rct6603w47 but now I get this settingslocked message when I try to pick language how do I bypass or unlock the settings it is a display model from target is it possible to reprogram or bypass settings locked password
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
已选择的解决方案
try the default password which should be 0530. you can usually find it online.
这个答案有帮助吗?
得分 0
7条评论:
The default password doesn't work
完成的
Not really sure what else to say because i have not been able to bypass this on the newer models. i would think a factory reset would reset this password to default but that may not be the case.
完成的
i used 20160502 for pro12
完成的
I found number in recovery mode
under view recovery logs
top one in those lines says recovery logs
then look for line that says rca password.
that is how i found it.
good luck
完成的
exelente me funciono del metodo comentado
good luck
完成的
显示更多的2条评论
添加一条评论
最有帮助的答案
The password is different for each tablet. If you go to recovery logs in the reset, choose the top one and slowly scroll down and it will
ro.build.version.sercuity_patch=2016-06-01.
The settingslocked password is is those 8 numbers is what I found mine to be. So that everyone has the answers finally.
这个答案有帮助吗?
得分 2
2条评论:
mine said rca lock key 20160502
完成的
Yes that is the same thing as well it is really the date in which it was made.
完成的
添加一条评论
这个答案有帮助吗?
得分 1
1条评论:
mine, too! So it was manufactured the same year?
完成的
添加一条评论
I tried it but it didn't work, keeps asking me for the previously synced account!
这个答案有帮助吗?
得分 0
1条评论:
This is a completely different thing. SettingsLocked is basically a feature to lock the settings for store demo devices. Yours sounds like you factory reset it using the volume button method and thus that is how this one happens.
完成的
添加一条评论
Sorry for bumping an old thread I have two of these Viking 2 10 inch that have same issue, but i tried the security patch date and and the date it was made but still locked..any help would be appreciated
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
You have 3 other options. In recovery logs look for
ro.boot.hardware=mt****
use the 2 letters and 4 numbers you see.
Next,
ro.boot.serialnumber=***********
use the first 8 digits or the whole serial number.
3rd,
ro.build.id=MRA58K
use the letters an numbers exactly as they appear.
Hope this helps you.
这个答案有帮助吗?
得分 0
3条评论:
i had tried every thing but setting locked is still annoying
完成的
i have bought RCA viking 2 from someone but has setting locked, and cannot connect to PC i have tried Factory Reset ,recovery mode, insert default pasw 05230 but i am failed :) if anyone can help would be appreciate
完成的
Just received a 2019 RCA Endeavor tablet locked in retail mode from what appears to be a previous Target store display....anyone know what the password might be? TYIA
完成的
添加一条评论
添加你的答案
dak joe 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 10
过去 30 天: 17
总计 5,645
