跳转到主内容
加入维修社区 - 创建账户
1.8GHz dual-core Intel Core i5 or dual-core 2.0GHz i7. (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
Why don't I have permission?
I bought a replacement SSD (pre-owned). When I power up, it would only go to recovery drive. Name of the drive was "osx 10._._ (clone)" it was encrypted (el capitan).
So I erased it and installed Sierra. It keeps telling me I don't have permission. Come to find out It has a VM 2 GB partition, Recovery 700-800 MB.
In Disk Utilities when I go to info on the main drive owner enabled says yes, on VM says no, on (my) Untitled says no. how do I change at least the untitled to yes? Is there a way in terminal or single user mode to give myself permission?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The VM volume is the systems BIOS image (EFI). So if someone enabled hardware locking on their system the image copy will have it enabled. So if you placed the SSD in your system the SSD is locked with their user ID.
So to fix this you need to completely erase the SSD. You'll need to either setup your system in Target mode with a second Mac or you'll need an OWC external drive case to hold your new SSD so you can use Disk Utility to fully wipe it clean. Then redo the drive. One last point here is the OS version you use as High Sierra now uses a different format (APFS) on SSD's which could also be a factor here as well.
这个答案有帮助吗?
得分 2
1条评论:
Thanks alot dan
完成的
添加一条评论
添加你的答案
Paul Perez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 128
