跳转到主内容
加入维修社区 - 创建账户
No pod required, single serve coffee brewing system with built in frother. Coffee drinks that can be made hot, iced, or other specialties and from a one cup serve to multi-serve. This device can be identified by its model number CF111 30.
Cleaning light won't go off
The "clean" light always goes back on even I just did the whole cleaning and flush cycle. It happens like weekly or daily. I think it's a faulty programming there. Is there any way to disable the light by modifying the circuit board or reprogram it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
https://m.ninjakitchen.com/include/pdf/c...
这个答案有帮助吗?
得分 0
添加一条评论
I finally figured this out after 3 of these machines…there huge buildup of calcium in upper passageway, between the silicone hose and the shower head. Take pump off of heater, blow from shower head with compressed air. Clean out heater really good, then reassemble. Run a clean cycle however you like.. Should be good for another year.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
infinity_bless 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 26
总计 10,291
