Cannot remove the screw inside magnetic cover
I've tried to unscrew it for literally 5 minutes.
I'm sure it's loosened but it doesn't lift.
It's just stuck in the cover.
it has no hard drive in it, give it a smack. alternatively, do the other screws and it should still come right off as the screws are not anchored.
这个答案有帮助吗?
i've tried to smack it but feared that the hinge will be broken.
And what do you mean the second option? just pry it anyway since the middle one isn't anchored? It does feel stiff when i try to pry the edges.
Oops! I forgot to check if we have a guide, just follow this guide. 戴尔 XPS 13 后盖更换
这个答案有帮助吗?
this doesn't mention the middle screw...
i'm confused right now whether or not i should force it...
Hmmm... whats your model?
its xps13 - 9350
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 330
