跳转到主内容
High Sierra on 3rd Party SSD
Has anyone managed to install high sierra on a 3rd party ssd ?
seems to work fine on sata ssd's
but when i tried on a macbook air 11" early 2014 it won't install
Update (02/12/2018)
I found a solution after talking to OWC
https://eshop.macsales.com/Service/Knowl...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Do you have an OWC SSD? If you do there is a known issue with High Sierra with there SSD's running APFS. Review this: A Note on High Sierra Compatibility with Third Party SSD's
At this time I'm still waiting for Apple to fix a more generic issue with APFS running on SATA based SSD drives besides the special case with OWC's SSD's. The issue Apple has a queuing issue within the APFS and the Finder process so you'll encounter issues trying to save documents and URL's.
If you own an older Unibody MacBook Pro with an SATA based SSD you want to stick with Sierra for now.
这个答案有帮助吗?
得分 2
4条评论:
thanks, i had already see this online, was just wondering if anyone had got any further.
完成的
I would contact OWC to see what they say.
完成的
Found a solution to that now.
完成的
Thats great news! Were you able to apply the firmware update to fix the issue?
完成的
添加一条评论
添加你的答案
Lorn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,238
