Laptop won't stay on unless it's hook up to the charger
My laptop won't stay on unless it's hooked up to the charger. Once you unhook it, the laptop shuts off! When it's hooked up it runs fine! Does it just need a new battery or what??
Double check to make sure you battery is seated properly first. But going off your description of the problem you are having a new battery would most likely fix the issue since it works fine while connected to a charger and shuts off after removing the charger. This does sound like a faulty battery and I would recommend replacing the battery to fix your issue.
这个答案有帮助吗?
Your battery may need replaced. Until you can get it replaced, just keep it plugged in while you're using it and it will stay on.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 1,467
