跳转到主内容
加入维修社区 - 创建账户
Laptop won't stay on unless it's hook up to the charger
My laptop won't stay on unless it's hooked up to the charger. Once you unhook it, the laptop shuts off! When it's hooked up it runs fine! Does it just need a new battery or what??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Double check to make sure you battery is seated properly first. But going off your description of the problem you are having a new battery would most likely fix the issue since it works fine while connected to a charger and shuts off after removing the charger. This does sound like a faulty battery and I would recommend replacing the battery to fix your issue.
这个答案有帮助吗?
得分 0
添加一条评论
Your battery may need replaced. Until you can get it replaced, just keep it plugged in while you're using it and it will stay on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Justin Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 23
总计 1,541
