跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Home button flex cable broken
Hi guys I have an iPhone 6s Plus lcd screen which I replaced and during the replacement I somehow damaged the components on the long flex cable attached with the lcd so now when I connect the home button to the connector the button doesn’t work but the home button is absolutely fine with other lcds so I was wondering would I be able to buy just a long flex cable attached with lcd or do I have to buy a new lcd ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
With that particular model, it is very common to damage the little cable built into the LCD, you will need to replace the entire LCD in order to fix the cable issue as the cable is built onto the backlight of the LCD and is extremely hard to replace individually.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 491
