跳转到主内容
微软第三代Xbox游戏机于2013年11月22日发布。
727 个问题 查看全部
Lightning strike on the HDMI port
My Xbox had the cable box video set up on it and lightning hit and everything went out and now the picture on my Xbox doesn't look right and I don't know how to fix it . It still works and everything but the picture is small any help would be great if anybody has any ideas
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Is it stuck in low resolution mode? If yes it's probably a HDMI chip / circuit fault. A reputable console repair store can get that fixed for you. Might be one available locally.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Try unplugging everything including the plugin brick (if you are using one) for a minute or two then pulg it back in. Also unplug any usb drives and take out any disk beforehand.
这个答案有帮助吗?
得分 1
1条评论:
Not a foolproof plan but that’s what works with some things.
完成的
添加一条评论
Are your devices plugged into a surge protector or a power strip? Surge will be bulky and power strip a thin bar with outlets. If it took a lightning surge without surge protection it's going to be VERY difficult to identify the problem unless you've got professional training in electronic repair. If there wasn't surge protection you're “lucky" it even powers on at all to attempt to fix it. Unless you have pro skills I only see 2 options, 1 take it to a pro 2 replace the entire system. Unfortunately either way you pay out of pocket. New console would probably be your best bet. Even if a professional gets it working there's 0 guarantee that other parts won't soon follow suit of the original damaged components. If other parts took damage but not enough to fry them than providing full power to the system will only compromise them. Sorry I can't offer better advice
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chuckwaqon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 1,540
