跳转到主内容
Android OS / 4GB Capacity which can be upgraded to up to 32GB / Model A270a / Black and White
80 个问题 查看全部
How do I answer this phone?
My phone rang and I did not know how to answer it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
No instructions to do that came with the phone. Thanks!
完成的
There is no green icon to answer the phone. Did I accidentally do something that there is no green icon appeared in my phone as someone calls in. I can hear the ring tone, but there is no green icon to answer. Please advice.
完成的
添加一条评论
1个答案
已选择的解决方案
Phone rings, the phone will open a different window that displays a Green icon, to answer, and Red icon, to decline call, screen. You need put your finger on the green icon and slide it towards the opposite direction.
这个答案有帮助吗?
得分 2
2条评论:
sort of....hold the dot in middle of the screen when phone rings until the green icon appears and slide in opposite direction.......%#*@. Could of made it a lot easier!
完成的
Tried your suggested answer method. No joy ,unless the caller is on my list of contacts, then I can answer with the bar at the top of the screen which has Answer or Decline choices. Most times I have to find out who called ,under Missed calls ,then call them back.
Please help. Linda
完成的
添加一条评论
添加你的答案
greg burgoyne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 32
总计 3,660
