跳转到主内容
LG在2016年9月29日发布的LG V10的后继产品,类似LG G5。LG V20分为F800, H910, H918, H990 DS Dual, H990N Dual, H990T, LS997, US996, and VS995数个不同型号。同时,提供了钛金灰、粉色等不同颜色。
51 个问题 查看全部
LG V20 no gps signals
Does anyone know how to fix the LG V20 that can't pickup any GPS signals?
I tried to tighten all of the screws in the back plate, clean the contact terminal (even pushed it up a little bit) and the antenna terminal. In addition, I have tried the Aluminum trick by adding a layer of Aluminum between the antenna's terminal and the phone's contact terminal. None of these tricks fixed the issue. Also, I reset the phone, but no lucks. Any suggestions/recommendations are greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Major GPS issues. High Accuracy is on.
this is only two months old. LG refuses to warranty because it is an "unlocked" phone! (what??)
Newegg won't help. I am DONE with LG. Never again. My G3 had really bad wifi.
Now really bad GPS. Also LTE cell reception is at least two bars lower than anyone around me is getting on the same network.
I liked this phone for the hi audio quality but bad reception and bad GPS is a deal breaker. Wish I knew this before I bought.
这个答案有帮助吗?
得分 0
添加一条评论
if you bought a refurb unit likely they put the wrong bezel on the top. takes like 3 minutes to fix. I fixed mine by adding copper tape from this link went from zero satellites to 10+ instantly
https://www.reddit.com/r/lgv20/comments/...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jack 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 3,576
