跳转到主内容
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
75 个问题 查看全部
Will Dell XPS 13 9360 motherboard work on my Dell XPS 13 9350?
I am replacing the motherboard on Dell XPS 13 9350 -i7 and currently have an option to install 9360 i7 motherboard. I think chassis (dimensions) are exactly the same, but I wonder if the new motherboard version works with older chassis/ older PC version?
Any advice/tip is welcomed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
UPDATE:
I was not successful installing this motherboard:
As was indicated by professional laptop service I went through, the potential problems are with the internal power supply and BIOS. And if the latter can be fixed, the former can seriously affect motherboard performance. The electric circuits diagram we found online did not explicitly indicate power levels, so we opted to use safest, ie older version of the motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi. I think in this case you most likely need to replace the battery and make sure your screen and screen cable are compatible with the new motherboard. P.S.This is all pure theory.
Cheers,
Yevhen
这个答案有帮助吗?
得分 1
添加一条评论
Did you ever figure this out. I am trying to figure this out as well
这个答案有帮助吗?
得分 0
1条评论:
Hi, I was not successful installing this motherboard:
Apologies for being unassertive!
完成的
添加一条评论
Hello,
I upgraded my 9343 to the 9360, I also bought the larger capacity OEM battery. The palm rest is also different, so buy a new one as well :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Oikk Waclaw 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,675
