跳转到主内容
Windows 8 touchscreen-compatible version of the Zenbook Prime UX31A
9 个问题 查看全部
Can I install Lenovo's Synaptics Touchpad Driver on Asus UX303UB
Hi
I owned a Lenovo before purchasing the UX303UB in Jan 2018. I truly hate this touchpad. Waaaay too sensitive and it constantly interrupts workflow with a range of things opening up. I have turned down sensitivity to its lowest and still a problem. I would love to use the synaptics driver I had with my old lenovo but I was told by Asus Official support that it is not compatible. I have my doubts and wanted to ask the team here if it was possible.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
In case its important I could not find model in the list so I chose the closest but mine is a UX303UB Windows 10 64 bit
完成的
THanks SW. I should have more accurately shared that what Asus had said in fact was that theirs was the recommended one. Which is expected but interestingly they didn't say it could not be done.
I also suspect Smart Gesture is the problem. I have reduced the sensitivity there to the lowest.
To switch it off completely would mean losing all the features that I do use for the touch pad. But I would drop it in a heartbeat if I could get synaptics to work.
完成的
添加一条评论
1个答案
I don't know what the manufacturer of your touch pad is. Asus looks to be using some proprietary stuff.
What I recommend is look 2 places:
Look for Asus Smart Gesture or Control Panel --> Touchpad or Control Panel --> Mouse (something like that).
You can customize sensitivity using either of those 2.
However, I think it may be the smart gestures that are annoying you. You can look into turning those off.
Make sure you downloaded the latest version.
这个答案有帮助吗?
得分 0
1条评论:
You could give the Synaptics a try. Since this post has the direct link to ASUS smart gesture, you can revert if it doesn't work out.
Aside from Synaptics, there is another major manufacturer called "Alps". Please note that the drivers aren't interchangeable.
完成的
添加一条评论
添加你的答案
Jeanette Calder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,078
