跳转到主内容
加入维修社区 - 创建账户
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Screen goes extremely dim
My screen is almost always extremely dark (no icons visible just very dim light) sometimes it helps to hit it on the back a few times for a few minutes but then it goes flickering/ green to black again. I also tried reset and completely reinstalling it without luck. I guess the LCD cable is loose? How much would a repair cost?
Edit: sounds like a backlight problem according to a local repair shop, he said repair costs 120€... is it possible to fix it by myself, without technical super skills?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Depends. It could be the LCD going out (which is a DIY) or a backlight coil, which would need micro soldering.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for your answer! "LCD going out" means I have to buy a new LCD screen for109$ ?
I wonder if I could fix it somehow with a harder hit on the side as the screen works perfectly sometimes...
完成的
You should have a warranty from your supplier.
完成的
添加一条评论
It is better to fix it hitting it just rigs it to work for a while just replace it alway the way to go. And how about having the lcd tested on another I pad this will help diagnose what the issue is!
If you have any questions or concerns please comment below. Thank you
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bastian 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 33
总计 482
