跳转到主内容
How to Plug in Headphones when the Jack is broken?
So, about a year ago. I broke my headphone jack by accidentally tripping over an earbud cord connected to it, and the port is stuck deep inside.
Now, I have recently gotten a pair of Turtle beach Headphones! But It doesn't seem to work as I can only connect one port inside.
Any suggestions on how to fix and use my headphones?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
about how much is in there and how deep?
完成的
Ah! My bad,
my earbud adapter is stuck inside.
Its deep enough where I can't get it out, even with the super glue method.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
What is the make and model number of your desktop or the make and model number of the motherboard if self built?
Where is the headphone socket? On a panel in the front of the computer case or at the back of the case on the motherboard?
If it is on the front of the case usually the "audio \ USB panel" (example only) is connected by cables to header pins on the motherboard.
The simplest way to resolve the problem, if your setup is like this, is to replace the panel containing the audio socket
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
WaterWolfGaming 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,238
