跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Home Button Nowhere to connect to
So my Moms iPhone 6 had the problem that the Home Button sometimes didnt register when being pressed to finally to work anymore.
I ordered a new Home Button off Amazon and tried to replace it today, when i wanted to disconnect the old Home button from the flex cable i quickly realized that there was nowhere to connect the new one, i thought that i may ripped off the connector but that was also not the case.
Pictures : https://imgur.com/a/Ex6oz
Would i now need to also order a new Home Button Flex cable and replace that ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Its ripped.. the connectors on the flex are probably stuck in your mothers homebutton. You’ll need a new backplate.
iPhone 6 LCD Shield Plate with Sticker and Home Cable
iPhone 6 LCD Shield Plate with Sticker and Home Cable图片
产品
这个答案有帮助吗?
得分 1
2条评论:
okay thanks for your help, is it also possible to just buy the flex cable and go with this tutorial : iPhone 6 Home键 线缆更换
or does the Sticker not stick as good anymore after opening it up ?
完成的
You could just order the flex cable, but I personally only orders the complete thing.
完成的
添加一条评论
添加你的答案
KekoMaster Atmisbir 2 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 64
