跳转到主内容
Acer Iconia A3 is a 10.1" Android 4.2 Jelly Bean tablet powered by a quad-core Mediatek processor.
11 个问题 查看全部
Front glass undamaged, when screen turned on I see cracks
I have just recently sat on my Acer Iconia Tab 10 A3-A40. There are no scratches on the front glass, if I run my fingers over it, I do not feel anything.
When I turn on the screen, it shows cracks over black background, touch is not working.
Can someone please help me find what parts I need to buy? I am unsure, but I believe I need to buy a LCD screen with digitizer. Or can I buy only LCD screen and re-use the digitizer?
thank you for your help guys!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
It seems that those are all the symptoms of a cracked LCD, so you would only need a LCD, and you could most likely reuse the digitizer. Hope that helps!
这个答案有帮助吗?
得分 1
2条评论:
Thank you Reed! I will order an LCD and try to fix it.
完成的
@peterslo No problem! I'm glad I could be of assistance! Good luck with the repair!
完成的
添加一条评论
添加你的答案
peter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 203
