跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
373 个问题 查看全部
Black Screen of Death - Replaced Motherboard
A little back story about myself. I am a pc repair technician and have over 10 years of experience fixing various electronics. I also have my own repair business. A client has brought me a Nintendo 3DS XL 2015+ model. The unit has the "black screen of death".
When turned on I can hear the menu music but there is no display. If booted into safe boot mode, both of the screen are operational. After doing some research it appeared that motherboard may need to be replaced to resolve the issue. I have replaced the motherboard with no change.
Is there something else that would be causing this issue? Any other items I should check? Could it be that I just got a defective replacement board?
EDIT:
After more troubleshooting I have discovered there is a problem with the camera(s). The unit powers on and is fully function when the camera ribbon is unplugged
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
I am not a technician. But the area you should check out is underneath the left button.
这个答案有帮助吗?
得分 0
添加一条评论
In some cases it may be a lose wifi chip. But if u changed the motherboard that may not be the case. Tho i once repaired a samsung s9 phone that didn't turn on by just taking out the camera. The camera had a short circuit i
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bigbiniecki 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 21
总计 642
