跳转到主内容
High-end multimedia laptop by Asus.
9 个问题 查看全部
I need screws for bottom cover near hinges
Got a Asus N551Jq trying desperately to find a screw that will secure bottom case to the front case hinges stay shut. (the two holes on bottom cover) requires I believe two long screws anyone know where I can purchase this? Or know screw type looking everywhere.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I already know about this but I don't know what size I need and postage is ridiculous to take a gamble.
完成的
添加一条评论
4个答案
最有帮助的答案
Hi all,
just in case anyone needs it in the future.
Red: 2 screws (M2.5*10L) / connect bottom - hinge - topcase
Blue: 4 screws (M2*5L)
Purple: 2 screws (M2*3L)
Here you’ll need 2 longer screws (M2*16L)
These 6 screws (M2.5*4.5L) connect hinges to the bottom case
Basically, this list is applicable to both gaming (ROG G551 / GL551 / G58 series) and non-gaming (N551 series) models. Some minor differences may exist for TOUCH models.
这个答案有帮助吗?
得分 2
1条评论:
hey do you have something like this for the asus fx504gm model?
完成的
添加一条评论
And a bit more detailed overview for the FX504GM:
Let me know if you need more info about some other screws for this laptop.
Cheers!
这个答案有帮助吗?
得分 2
6条评论:
perfect thanks! do you also know the screws that connect the hinge to the lcd back(behind the lcd bezel)
完成的
@Dante Xavier, yeah, you'll need 2x M2*2,5L for the top and 4x M2,5*3L for the underside of the LCD cover.
Just to add, LCD panel should be attached using 4x M2*2.5L.
Cheers!
完成的
So in total 8 x M2,5*3L for the both hinges in the bottom left and right to be connected right? Also 2x M2*2,5L for the top of each hinge to the back lcd cover?
完成的
@Dante Xavier, nope, just as said before 2+4 is for both hinges.
Take a look - I've added a picture of how it should look like :)
完成的
thanks so much! also for the hinges in the second picture is that 4 on each side for a total of 8?
完成的
显示更多的1条评论
添加一条评论
Hi,
Don't know if this is a help to you or not.
Here is a link that shows ''all'' the parts that are available for your laptop.
Scroll down and click on the screw link to get a list of the screws and their sizes,
e.g. M2.5*10L = metric screw 2.5mm wide x 10mm long
这个答案有帮助吗?
得分 1
1条评论:
Hi,
Well there are only two long screws sizes mentioned and since they are a standard metric size suggest you try the local hardware store.
Either M2*16L or M2.5*10L
完成的
添加一条评论
Hi @Dante Xavier
Not the same detail as above but here are all the screws sizes available for the laptop model.
Just select the "Screw (14)" checkbox.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adam UKGaming 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 13
总计 2,603
