跳转到主内容
加入维修社区 - 创建账户
2014 年 2 月发布的 10.1 英寸平板电脑,运行三星定制版 Android 4.4 KitKat,型号为:SM-T520NZKAXAR
Is it possible to hardwire a rj45 connector to the motherboard?
Hi all.. i have an old galaxy tab pro that has a cracked screen.. and i am using it as an android media center using kodi..
I have a mhl micro usb 2 hdmi adapter with remote that works very well.. but i would really like to loose the wifi and use a ethernet connection.. but i dont know if this is possible... is there anywhere on the mainboard where it would be possible to solder an rj45 socket to...
And just fyi the mainboard is no longer in the tablet casing but is in a homemade case..
Thanks in advance for any info on the subject..
Best regards
Kristjan
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Your Galaxy does not offer the Ethernet interface logic. Sorry guy no way to do it.
这个答案有帮助吗?
得分 1
添加一条评论
no
The PCB is printed, and programmed only for WiFi Adapters of a specific make. Not only is it physically not able to pin out on the board, you would also need to make your own IC on the device.
so as the answer is a flat NO. there is a hypothetical yes. if you are a technologist, with knowledge of the Samsung Mainboad Pinout for your model, the tools to make your own subboard, program a PLD to use as a Network IC, and repin the original Network IC to accept the new Sub PCB as an attachment. then perhaps something could be worked out. unfortunately all of these skillsets are different specializations for different jobs, and most people who know the intricacies of one, only know the bare basics of others.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kristjan Gudmundsson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 22
总计 424
