跳转到主内容
网络摄像头设备维修
10 个问题 查看全部
How can I fix my laptop’s camera?
I haven’t tried my laptop’s camera for over a year and when I tried to use it I got an error message saying something along the lines of, “camera can not be found.” I tried to uninstall the app and reinstall it but it does not show up under devices so I can’t update it or reinstall. I tried clearing everything off the hard drive and reinstalling windows 10, but when it was finished it still shows the same error message when I try to use it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Hi,
What is the make and model number of the laptop?
What app are you trying to use?
完成的
Hi @Warissar Oil,
Are you advertising or asking a question?
If you are asking a question then more details regarding the problem would be a help.
完成的
It’s a Toshiba Satellite c55-b5240x and the app is just Microsoft’s web cam app that comes preloaded on the computer
完成的
When I go to device manager ‘image devices,’ isn’t listed for some reason. I even opened all the drop down lists from every option under device manager.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @ashleypennybacker,
1. Check that the camera is turned on.
Go to Start > Settings > Privacy > Camera
2. Check the status of the webcam in Device Manager.
In the Search field, type Device Manager.
i. Click or touch the Device Manager application.
ii. Double-click or touch Imaging devices.
iii. Right-click or touch Web Camera.
Check to see if the webcam is listed in the devices and whether it has a red cross or yellow exclamation mark next to it.
If it has a red cross, right click on the webcam entry and then select enable from the options and then check if the webcam now works OK.
If it has a yellow exclamation mark, right click on the entry and select update driver and follow the prompts.
这个答案有帮助吗?
得分 2
1条评论:
Did you check the camera On/Off setting in Settings > Privacy > Camera? You didn't say.
Also just verifying that when in Device Manager did you click on the View tab and enable "show hidden devices".
If yes to the above then check in BIOS whether there is a setting to enable/disable the webcam or not.
(To get into BIOS Hold down the F2 key (BIOS) WHILE pressing the Power key. Don't wait for the splash screen)
完成的
添加一条评论
添加你的答案
ashleypennybacker 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 20
总计 552
