跳转到主内容
加入维修社区 - 创建账户
Black screen
-MacBook Pro was on sleep mode in laptop bag
- Bag fell on floor of car when I had to break
- Black screen , ,when i got home and tried to turn computer on
- Computer comes on but screen remains black
- Tried external monitor , nothing
- Iphone wont synch
what could be the problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
- try booting in Target Disk mode (reboot and hold down T key while booting), then connect via firewire to another Mac - see if you can mount your MBP hard disk on that other Mac. If so, immediately back up your important data from your MBP
if it doesn't even do that, you may have damaged your logic board. You can likely still save/backup your data if you take apart your MBP and remove your hard disk, then either install it in an external drive enclosure, our use a universal USB drive adapter, like this one
the fact that you don't even get a display on an external monitor is a bit worrisome and also may point to logic board damage. but before making that conclusion, try a few other things...
you could try reseating all the RAM modules, although if they were simply knocked loose, the machine would likely show some other signs of life. you could also open up your MBP using the guides here on ifixit.com and see if there are obvious signs of connectors that may have been knocked loose.
if you notice any other symptoms, report back here an we can try to help diagnose further. good luck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lees9 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 4,017
