跳转到主内容
The first generation Honda CRV, produced from 1995 to 2001.
97 个问题 查看全部
How do I know if the front CV axles are bad or the bearings
The driver side axle meets the inner shaft in wat looks like to me a carrier bearing then the shaft goes to tranny. Where my CV axle goes into the carrier bearing it has some play. You can shake it a lil bit by hand. The passenger side axle torge the tranny is throwing grease. The vehicle has over four hundred thousand miles on it also
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
hi test your car in a safe place turn the steering wheel to the right lock it hard and do a couple of rotations while listening for a grinding sound if you hear a grinding sound your cv joint is gone , now do the opposite and turn your steering to the left lock it hard and repeat the same procedure . where the shaft goes into the transmission on the drivers side there should be no leak of fluid if it is leaking you will see it on the ground. it sounds from what you describe on the passengers side where the grease is being thrown out that the cv rubber boot is torn thats where the grease is coming from once its splits, bits of road grit get inside and destroy the bearing if thats the case you will have to replace that side. to check the outer wheel bearing jack the car up (put jack stands under the car do not rely on the jack for safety) when the car is off the ground grab the wheel at the twelve and six oclock position and rock it back and forth if its loose this will tell you if there is play in the wheel bearing. hopes that helps chris
0
9
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Scotty Seitz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,633
