跳转到主内容
加入维修社区 - 创建账户
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
Will not charge or turn on.
Went to bed and power was at 7%. Did not plug in charger. When I got up the next morning, phone would not turn on. Plugged in the charger, still did not turn on. Left it on the charger for one day, still did not turn on. Changed chargers and cords three times and tried wireless charging, you got it, still did not turn on.
In all situations the charging light never turned on, the charger never got warm, and the phone never got warm. However, when the phone is plugged into the charger and I do a soft boot, barely visible bars flash intermittently on the bottom half the phone screen.
An online search indicates this is not an uncommon problem and frequency is increasing. Verizon will honor the warranty because there is a small crack on the left side of the screen. This is been there for five months without causing any problems.
My thinking on possible problems:
Battery needs to be replaced;
Charging hardware Is defective.
Charging firmware or software is crap.
I am wide open to suggestions and troubleshooting. If nothing brings my phone back to life, is it possible to recover the data?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
I had two Samsung Galaxy S4 that went dead.
One thing I observed, prior to their demise, was that the phones were warmer than usual when charging
My theory is that repeated overheating would cause some chips or circuits to fail.
I have bought an external charger for the batteries and bought also spare batteries, so that I will never have to recharge them with the cell phone again.
Just install a fully charge battery everyday.
完成的
添加一条评论
2个答案
最有帮助的答案
Try holding volume down + power for about 10-20 seconds and try turning the phone on again. Hopefully that helps.
这个答案有帮助吗?
得分 2
添加一条评论
Hey hows it going I had the same issuie and what I did is I started wirelessly charging it then went to try it again through the usb c port and it charged whih was like a week later so gibve that a try for awhile and see if it corrects itself down the road
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
Jack Zeigler 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 9,941
