跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Upgrading my Mac system's SSD
I have A1502 MacBook Pro (mid 2015) this is the last 4 letters of the serial number : FVH3
I wanted to ask which ssd can I use to upgrade to 512GB ?
Can I use this one? Samsung 960 pro M2 512GB
or this one: Samsung 960 EVO
thank you all
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your system uses a custom blade SSD which happen to be made by Samsung for Apple, while similar to a M.2 SSD it is not pin compatible. Your system has a AHCI/PCIe x4 (4 lane) interface.
I would recommend you stick with the correct drive made by either OWC or Transcend. Both make replacement SSD's designed to work in your system.
Here's the IFIXIT guide to replace the SSD: MacBook Pro 13 英寸配备 Retina 显示屏2015年早期版SSD更换
这个答案有帮助吗?
得分 1
4条评论:
I saw that in 10.3 ( high siera) apple support custom ssd
Or that isnt true?
完成的
I'm not sure I understand what you're saying here. There are mechanical & physical limits within your system. The issue is not software you can only use a AHCI/PCIe SSD not a NVMe/PCIe SSD.
Think of it like gasoline and diesel fuel they both run cars & trucks but you can't use one fuel for the other.
完成的
https://eshop.macsales.com/item/Other%20...
I guess I will stick with this one then :)
I saw not much AHCI ssd out there and most are disconnected...
sad to see apple only used this type as her MacBooks ssd
ty sir anyway :)
完成的
@fooad444 - Apple was ahead of the curve with blade SSD's.
The issue you're facing is just the speed of change! AHCI based systems are still being sold from Dell and Lenovo. But, the move is on to NVMe/PCI for the upper end systems!
All of the 2016 and newer Mac's use NVMe drives. In fact Apple's new iMac Pro is using interleaved raw flash which is even faster than NVMe based SSD's!
完成的
添加一条评论
添加你的答案
fouad taha 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 6,499
