跳转到主内容
The HP LaserJet CM1415fnw is a multifunction color printer produced by Hewlett Packard.
19 个问题 查看全部
Always posting Misprint mess after the first page, then Cleaning mess
When I print it will stop after the second page and say “Misprint” then when I select continue it will print the last page that it printed and the next page.
It will then say Cleaning and then it will say misprint again and print the last page and the next page and so on and so on;
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Have you replaced the drum and toner?
You may need to give the printer a good clean.
这个答案有帮助吗?
得分 1
5条评论:
I have the same problem, cleaned it with compressed air, changed the cartridges, but there doesnt seem to be a changeable drum
完成的
All Laser printers use a drum.
Do you have a Jet printer which uses liquid color cartridges?
完成的
Nope, it is the cm1415. There is no mention of a drum even in the servicemanual
完成的
The drum is part of each of the color cartridges.
Check the paper feed rollers. If you used a refilled cartridge it may be bad.
完成的
I have used original cartridges, imitation ones and originals at the moment. Unfortunately I tried to clean the pickup roller yesterday... With silicone spray..., yes not very smart haha, so I ordered a new set of rollers, including a transfer roller. Hope that will do the trick
完成的
添加一条评论
I think it might be an online anomaly, does the indicator light blink?
这个答案有帮助吗?
得分 0
添加一条评论
Try replacing or cleaning the pickup roller. There is a YouTube video that explains the procedure. I took mine out and cleaned it with a rough sponge and dish soap. Works great now.
Replace or Clean Pickup Roller on HP Pro CM1415fnw
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jen cokoa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 22
总计 1,614
