跳转到主内容
Not working display, what should I replace Display Data Cable or LCD?
Hi guys, my display is not working anymore, the mac is working absolutely fine with an external screen, but I dont know what should replace the Display Datqa Cable or the LCD. thanks
Update (01/22/2018)
thanks for your answer men!, i will doit
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
What does the flashlight test show you? Take a flashlight hold it on the screen at a sharp angle (about 20 degrees) are you able to see the faint image of the desktop and the icons? If you do the issue is the backlight circuit on the logic board Vs the display.
这个答案有帮助吗?
得分 2
添加一条评论
There is not really a way of telling which it is so I would start by replacing the Display Data Cable and then if that doesn't work then replace the more expensive LCD.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel Murrieta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 64
