跳转到主内容
Repair information for Etch A Sketch toys.
How to repair etch a sketch
This is an etch a sketch from the 80's. White knobs turn, but there is no drawing. Can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
Did any body find any answer to this problem?
完成的
What if it’s leaking aluminum?
完成的
I've heard of problems like this a lot so this could be a common issue with etch a sketches
完成的
Mine just will not draw idk what is wrong with it if some one can pls help me that would be nice it is something I use to help with stress and paying attention and dont really wanna buy a new one if you can help me that would be amazing
完成的
Mine stopped working the day I got it the vertical line knob stopped working -_-
完成的
显示更多的1条评论
添加一条评论
3个答案
最有帮助的答案
An Etch-A-Sketch is a simple machine where the knobs end up moving a string from side to side and another from top to bottom. If the strings stretch or for any reason slip, you will get the behavior that you describe. Other than opening up the unit and replacing the string, there is not much that can be done.
Dan
这个答案有帮助吗?
得分 1
添加一条评论
This seems like the same problem: Can I fix dead areas on the screen, where lines don't appear?
这个答案有帮助吗?
得分 0
添加一条评论
How do I fix a etch a sketch if it has a see through screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lisa 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 35
过去 30 天: 137
总计 14,650
