跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Why my phone gets very hot in seconds and drains insane the battery
My iphone 6s plus does not charging any more and if i put a charged battery it get stuck on apple logo, i can put it in recovery mode or dfu mode( it recognise the cable) but does not connect with the pc, can it have something else than the u2 chip?
Update (01/24/2018)
Now if i put the phone on airplane mode it work fine, even on antutu benchmark with airplane mode off i hot 80000 and airplane mode on 135000, it does not drains battery and does not get hot, can i fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your Tristar (U2) IC is probably damaged. This IC handles all communications with whatever is connected to the Lightning port...that includes the battery charger and computer. However it can happen that the charging is affected but not communications with the computer.
这个答案有帮助吗?
得分 2
6条评论:
Thanks for help, i took it to a repair shop and they told me its not the u2 ic because its not booting, can there be something else?
完成的
A failed U2 can also cause boot issues...it depends how the circuit fails. Did they even open it up and take a look at it?
完成的
Yes, they have change the u2 and now the phone is charging but still not booting or connecting to pc, i am not sure ifthey did it right
完成的
Since they already changed U2, then tristar isn't the fault here as it's still getting stuck on apple logo.
Have you tried updating the phone first to see if that helps? If you get an iTunes restore error, post it here.
Also if you want you can also try restore but only do that option if you dont have any data to backup from the phone.
完成的
Problem solved, it was a faulty rezistor and the u2 chip, now it works, thank you for your help
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Alin Ghetu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 680
