跳转到主内容
The BLU Vivo XL was released in January 2016 as part of BLU's budget line of smartphones.
Unable to hear during outgoing calls
After the latest update to my BLU XL2 I am now unable to hear during outgoing calls as well as any sound with the speaker during the calls or with Google assistant. My speakers work fine when watching video. Everything is fine when I receive a call.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
7条评论
You are correct @Grandy. It is the Google app. When I allow microphone permissions within the app the problem persists, but as soon as I disabled permission for the app. It went away. Thanks for your help!
完成的
Gabe........How did you disable permission for the microphone? Thanks in advance. Joe
完成的
I have this too! I can't hear a call when calling out, but when someone obviously answers, I press the record button & I can hear. Ugh. Thank you for the feedback, I took the ok Google advice as well as the carrier service. I'll see what happens!
完成的
Thank you for this...I've had this same problem after the last update. Disabled the ok Google... problem solved.
完成的
I hve buy vivo y 81 one month ago, but there a hearing problem, I am not able to hear incoming as well as out going calls . Tp hear calls , I have to on loud speaker. This the problem in this phone.
完成的
显示更多的2条评论
添加一条评论
3个答案
已选择的解决方案
I had this problem after the update also. I figured out it only happens while I have "Hey Google" activated. If I disable the "Hey Google" feature everything works fine.
Google account/settings/voice/voice match, and turn off Say "Ok Google" any time.
这个答案有帮助吗?
得分 8
8条评论:
Thanks for the feedback. I also corrected the issue by disabling microphone and phone permissions in all apps that had those specific permissions. There were only 5or 6 total. The issue has happened since but I haven't pinpointed the actual app that is causing the problem. I will update once I do. Thank you.
完成的
Thanks Grandy, I can hear again. I contacted BLU and turning off "OK Google" is the remedy they're recommending as well, until a permanent solution can be found.
完成的
Your welcome. Glad to be of help.
完成的
Grandy, I thank you for getting me on track again. Your remedy is spot on.
完成的
Thank You... I have been going crazy with this issue. I was about to toss my phone and get a new one.
完成的
显示更多的3条评论
添加一条评论
Hello, Thanks for easy answer!
Google Talk it's looks like it is a "Bug" or "Intercellular" and "google app" need to remove forever and put "Google Company" to Bring to Court for this interception to all Mobile Phones?
这个答案有帮助吗?
得分 0
添加一条评论
I have mi phone but I can't here in comming and out going calls
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 31
总计 27,069
