[Solved]6s Battery Replacement - Now Home Button Is Not Working
'''[ Solved - It was the screen ]
My Sister handed down her fully working iPhone 6s to my Mum. Just needed a battery replacement. It has been factory reset.
I have done a couple of ipads and a few 5c so the task wasn't a issue.
Do the volume up/down buttons work on the "Hello" freshly factory reset screen? Home button and vol keys do not work. Power and ringer swtich do.
edit: Vol keys are working.
No visible damage.
3条评论
-Reseated cables many times.
-Hard reset (Home/Power) doesn’t work.
-iTunes update and factory reset.
Touch screen is unresponsive at the 'quick start/manual set-up' screen but works at the ‘Hello’ screen: https://youtu.be/HkF7EnBLahI
由 Brent 完成的
I think you need to test an other screen because of the cable for the homebutton goes in those flex cables of the screen.
由 Jonny 完成的
It was the screen. Tested on a replacement. Thanks all.
由 Brent 完成的
