跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Why is my front camera not working after I replaced battery?
I watched some tips on the youtube which showed how to replace the battery briefly without removing the LCD. I did exactly the process with holding the LCD 90 degree throughout the time replacing. When I assembled the phone, I figured out that my front camera just show a black screen and couldn't take any photo, It still fine when switch the rear camera to the front camera, and the rear camera was fine. One thing I noticed that when I placed the battery inside and run the camera my phone keep restarting few times. I wonder where the problem was? My front camera or when I replaced the battery there was some shorting happened and it affected to the IC on the main board which control the front and rear camera?
Anyone can help me? Thank you so much! Cause now I'm very confusing, if I order the new front camera to replace will it solve the problem? or the problem came from the main board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Restarting issue is probably caused by defective battery.
The issue with the front camera is probably the front camera ribbon flex cable assembly damaged. Usually teared.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for your response ,but I checked the cable meticulously! There was no signal of teared or damaged. Still very confusing what should I order to replace.
完成的
It's always worth a try replacing the front camera cable even if it doesn't have any signs of damaged. Bending those cables past 90 degrees can damage them.
完成的
添加一条评论
添加你的答案
Khoi Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 4,872
