跳转到主内容
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
20 个问题 查看全部
What's the Capacity of Model 110 series 26432501?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
110.20022013 what is the capacity
完成的
添加一条评论
2个答案
已选择的解决方案
Kenmore 110 Series Washing Machine series washer capacity is 3.2 cu. ft.
这个答案有帮助吗?
得分 5
2条评论:
I have a washer that was in my condo when I bought it and need to replace it but want to know the capacity of the one I have. The model is 110.26422502. The serial number is CT0531376. Appreciate any help.
完成的
@mlphouston
To calculate the capacity (volume) of the tub, you multiply the area by the height. For example if your washer has a tub radius of 10 inches and the height is 14 inches, you would use the mathematical equation below.
Area is pi x r-squared = 3.1416 x 10-squared = 3.1416 x 100 = 314.16.
Volume = 314.16 x 14 = 4398.24 cubic inches.
There are 1728 cubic inches per cubic foot, so you divide 4398.24 by 1728 = 2.5452777 cubic feet.
So the cubic feet of capacity of this washer would be 2.5.feet
完成的
添加一条评论
Hi,
A quick way to do this is like finding the volume or cubic capacity of a cylinder, where the washer tub is the cylinder.
Calculating the Volume of a Cylinder
1. Measure the width of the tub and divide by 2 to get the radius.
2. Calculate the area of the tub:
To do this, just use the formula for finding the area of a circle, A = 3.14 x r x r (where r is the radius)
3. Measure the depth of the tub
4. Multiply the area by the depth.
Use the same measurement base e.g. feet for both the radius measurement and the depth measurement.
The answer will be in cubic feet.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 116
总计 43,994
