跳转到主内容
Second generation of the Acura TL.
10 个问题 查看全部
Car not reversing after removing battery
My 2003 accura stopped entering reverse after a friend used my battery to help someone. The problem was fixed only for it to resurface again but all other gear selectors are working fine. Advise needed urgently please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would try resetting the car's computer through removing the battery negative terminal for around 10 seconds. If that doesn't resolve the issue, I'd take it in to a mechanic (or auto parts store) to have them check for error codes via the OBD2.
这个答案有帮助吗?
得分 2
1条评论:
Thanks mate it worked once more thanks you are one in a million.
完成的
添加一条评论
添加你的答案
attom garba 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 113
