跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Why is my phone not making calls, and why can they not hear otherwise?
I recently replaced the battery and the charging port/AUX port/microphone and afterwards everything worked perfectly except now if I try to make a call it will not ring and will just give me the error that the call failed. I believe that I am receiving calls just fine, but if I get a call or if I somehow manage to make a call then the person on the other side cannot hear me very well at all. I seem to be cutting in and out or just not getting sound to them all together. Any ideas of what this could be, what to check or what I should do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This type of repair is not my forte, but is it possible a flex cable or something of that sort was torn in the repair? That seems like a logical source of annoyance after a repair. If you know that's not the issue, I would suggest (from a more solid background of experience than my above suggestion) that you try restarting it with the power/home button restart a few times - I know someone with an iPhone 6 that, for seemingly no good reason, has gone completely nuts on multiple fronts, including being wonky with the actual phone part.
这个答案有帮助吗?
得分 1
1条评论:
I did a factory reset and the problem seems to have gone away for now, if it comes back then I'll look at the internals again. Thank you!
完成的
添加一条评论
添加你的答案
Nathan Arnold 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 75
