跳转到主内容
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
My printer is saying paper jam with a loud noise
My printer is saying paper jam with aloud noise, why can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Im having the same issue. Did you find out how to repair?
完成的
I am having Epson L550, it's saying paper jam error, but there is no paper jammed..
完成的
添加一条评论
3个答案
已选择的解决方案
It will either have a latched door at the back or the bottom of the unit, to remove any stuck paper that may have jammed up the mechanism. Try looking for and opening that door and cleaning out whatever may be in there.
这个答案有帮助吗?
得分 1
2条评论:
Thank you this worked for us!
完成的
Thanks! The printer was instructing me to clear the paper from the paper cartridge/bottom of the printer... after seeing your suggestion, I opened the back of the printer and found two additional sheets stuck in the printer!
完成的
添加一条评论
I have a Epson ET-15000 and mine is doing the same thing and making a weird grinding noise but no paper in it anywhere. I’ve reset it several times and nothing changed?
这个答案有帮助吗?
得分 0
1条评论:
Just purchased the same printer and same thing, it was making a loud noise showing no paper but there was paper. Then now it was printing but the noise got louder
完成的
添加一条评论
I am having the same issue. Have you called Epson Support?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
June 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 10,354
