跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36478 个问题 查看全部
问题已关闭
iPhone 3G is dead. The power button is damaged
Hi,
My iPhone is dead. It suddenly went off and I can't charge it anymore. Since my iPhone's power button was already damaged I couldn't do the trick of holding down the power button and home button simultaneously to bring it to life.
Is there any fix for this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You could try doing a reset by holding down the home button and then plugging it into the USB cable plugged into your computer. That might turn it back on. You will have to restore your iphone when you do that though so if you don't have it backed up don't try that.
这个答案有帮助吗?
得分 1
添加一条评论
You can try resetting it by holding down the home button and THEN plugging it into the computer. It will come up in iTunes as being in DFU mode and will ask if you would like to restore it. You'll have to restore it and should be able to use the last time you backed it up to put all of your stuff back on it.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 554
