跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Boot Loop, Stuck on white screen with black Apple logo
Device: iPhone 6 Plus, 64gb
Service: unlocked
iOS: 9._._? Can’t remember
Issue: my original iPH6+ got touch disease and Apple replaced the phone with a new one. But I’m starting to think it wasn’t a new phone; maybe refurbished. So the new one worked for about 6 months then started to randomly turn off and sometimes get stuck in a boot loop. The phone has never been jail broken, or altered in any matter. It got to a point if I didn’t leave the screen on or something running (like playing Spotify) the phone would die. And then reboot loop would commence and sometimes I couldn’t get it to turn on and work for over an hour.
I did everything Apple told me at the Genius Bar, restored and what have you. Nothing worked. They said it was internal/hardware because there were hundreds of error logs, they were unable to fix it.
Well, I’m determined to fix it! They said I can trade it in for a price. I got a new iPhone but I want to get this one working.
So, the phone was rather easy to open. Like almost too easy! So, where do I go from here?!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I figured it wasn’t brand new. Ugh. Well, looking inside, everything looks okay. No water damage and it’s quite clean inside. Unless there’s something underneath I cannot see everything look good.
I’m not an electrician whiz, so I don’t know how to solder or install a new logic board.
Without the screen plugged in, how will I know if it turns on and is working properly? Is there a chance of electrocution?
完成的
添加一条评论
1个答案
已选择的解决方案
First of all, Apple did not replace your Touch Disease phone with a new one; it was a refurbished device, ironically, probably one that had Touch Disease in the past.
That means this phone, or at least the logic board inside it, has a certain history...it was probably twisted and flex enough to cause the issue. I'm speculating here but it;s probably close to the truth.
As for fixing it yourself, you most likely have a logic board issue and fixing that requires specialized tools and understanding of electronics. You could try to do a good visual inspection, look for obvious signs of damage such as (partially) torn flexes or signs of water damage. You could also try to disconnect everything except the battery and Lightning Dock, connect it to an iTunes enabled computer to see if it boots properly and is recognized. That would give you an indication that the problem is with the screen or peripherals.
Start with that and report back.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cassandra VerVaecke 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 3,801
