跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
What is a GPU and what does it do?
What does GPU stand for?
What guide should be followed to replace it?
What part should be ordered to replace it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
It might be helpful trying to understand why you think you need to replace it. Can you explain your reasons.
完成的
I have vertical colored lines when I boot up. I had white screen, then replaced the logic board, but now I've got vertical lines.
完成的
添加一条评论
2个答案
已选择的解决方案
GPU stands for: Graphic Processor Unit. Technically just the raw chip.
Often we use the term GPU Board, GPU Card or Video Card to describe the full assembly
Here's the guide: iMac Intel 20" EMC 2133 and 2210 Video Card Replacement
这个答案有帮助吗?
得分 3
添加一条评论
What the GPU does, is it renders all the stuff. Or, it turns the computers electrical signals into a visual that can be seen on the screen.
So its like
COMPUTER SIGNALS --> GPU --> DISPLAY
A GPU turns Computer signals into signals a display can recognize and display.
I worded it to make it simple and in my own words
Wikipedia article
Update (01/17/2018)
Heres a nice little block diagram of a PC
image found on www.graphicsbuzz.com
why am I including the source? I'm not a sponsor or anything. I don't want to get called out for accidentally infringing copyright again. Also that website is sketchy and gives you Microsoft support scams. Don't go there.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mchlgrblsk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 165
