跳转到主内容
非苹果电脑键盘维修指南。
242 个问题 查看全部
General disassembly strategy for new keyboard - Logitech G613
I want to investigate the innards of the G613 mechanical (wireless!) keyboard. The product has a known ping coming from both handling and its Romer G switches, possibly from echoing off an internal metal plate. This is a well built, beefy keyboard with a good fit and finish (unfortunately). I've removed all visible screws and run plastic cards along the circumference of the part gaps. Gotten some popping (I don't think any tabs broke), but nothing loosens. It's as solid and stable as can be.
There are foam pads I could pull to see if there are hidden screws, but I'm reluctant as I want to be sure I can replace or re-set a very good adhesive for a pretty expensive keyboard. There are only two small pads adjacent to the fold-out stands which already had screws underneath. I'm skeptical that there are more fasteners that close, though it's not impossible.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
4条评论
Well belay that. I've seen some comments and tests that make me conclude it actually is the switch springs resonating. Very unfortunate. If someone wants to go ahead and do a teardown or answer the original question for other people to see, please feel free.
完成的
do you still have that keyboard?
完成的
I do, but it is in storage. I switched to a Filco keyboard and am pretty happy with it.
完成的
There are in fact screws hidden under the foam pads.
I know, old thread but if anyone else was looking.
完成的
添加一条评论
2个答案
最有帮助的答案
Hey there, I just tore down my keyboard (long story short, I got bleach in it.) there are a total of 14 screws I believe and there are two under each long rubber part under he keyboard and one under the small rubber pieces near the stands of the keyboard. Then there is also one under the service number sticker right in the middle. Unscrew all of those then pop it off and you'll be at the back of the keyboard. There are more screws holding that into place so, if you want to take that out you'll have to unscrew those.
这个答案有帮助吗?
得分 5
2条评论:
What was underneath? I’m wondering if there are electronics under the palm rest. It not, I’m planning on disassembling and removing the palm rest myself.
完成的
Actually, it seems there are no electronics in the palm rest!
https://www.tweaktown.com/reviews/9202/l...
完成的
添加一条评论
I hope these pictures help
这个答案有帮助吗?
得分 5
3条评论:
Changing the switch does not need to unscrew inside.
完成的
Did you see any removable weights inside? The keyboard is so heavy I was hoping there would be some I could take out. Thanks!
完成的
weight seems to come from a solid metal chassis, I didn't see how we could remove it.
完成的
添加一条评论
添加你的答案
mmullins7 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 45
过去 30 天: 182
总计 18,450
