跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
Repair USB Flash Drive
I broke the connector off my USB Flash Drive and would like to repair to recover the photos on the drive. How do I solder and repair?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have gone on YouTube and found several sites that will help, but none of them can tell me how to make sure I have the wires going to the right place. any thoughts?
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @bcwright3 ,
There are plenty of videos on You Tube which describe various options on how to connect to the flashdrive to access the data.
The link above is just used to show you. Check out the list of videos down the right side of the page in the link and find the one that best relates to your problem and that you are comfortable with to do the repair.
Update (02/26/2018)
Hi @bcwright3 ,
If the USB connector was connected directly onto the pcb the by rights it should be a straight connection as shown in the image below.
Worst case would be if your put the power (+5V VCC) on the wrong connection as this would damage components.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Brian Wright 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 220
