跳转到主内容
萨博汽车的维修支持指南。
Gearbox is not working in right way
Hi everybody,
I have Saab 9000 CSE 2.0T/150 model 1996. It was working very nice. But suddenly the gearbox is not working . The car is starting normally but when i put gearbox on D drive it is not going . The complicated thing happend when i change the gear to normall +- the car is going then i back to D type .
Notice ; car`s gearbox is turbo tronic gearbox
If anyone have any idea for this problem or how i fix it .
Sincerlly
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
hmm... let me call iFixit's resident mechanic, @jimfixer !
完成的
Thanks for halping :)
完成的
It is possible that the neutral switch has shat itself. This would stop the vehicle working. Failing that, if it is an electronic transmission it could be the Transmission control module. Or possibly a fuse. See if there is a fuse for it first, then check neutral switch.
完成的
添加一条评论
1个答案
已选择的解决方案
Start By checking the fluid levels if possible in the trans . There are low fluid sensors in this gear box that will actually stop the car . aside from that there are a multitude of other possible problems that can stop this trans from working and the best bet to find out is get an OBDII reader that also reads transmission codes . Next, this line puzzles me could you explain this to me "The complicated thing happend when i change the gear to normall +- the car is going then i back to D type " . Do you mean you can shift the car manualy through the gears and it works but it just doesnt work when you use drive ? like to be more help if you can provide more information.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Eid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,363
