跳转到主内容
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
Home Button not position properly
I replaced the screen that came without a home button and when I went to attach the older one I used loctite to attach to the new screen. needless to say i did not correctly get it centered and the home button does not work properly.
I did try offsetting the bracket with the two screws to center the switch under the home button using on screw. Now it works properly and can i make a small hole in the mount and screw the bracket on or should i glue it?
Otherwise everything is working great.
Thank you,
Bill Haymaker
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I would glue it...making holes is usually a recipe for disaster. iFixit also sell a handy jig for placing the button bracket properly. You can find it here.
这个答案有帮助吗?
得分 1
2条评论:
is it too late for using the jig since i have already glued the mount to the glass?
完成的
If you can not take it off the frame, yes
完成的
添加一条评论
添加你的答案
disiciple 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 93
