跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Welcome screen keeps returning after reboot
Hi all,
I transfered all my data from my iPhone 4 to a iPhone 6. Everything went well and the phone is working fine.
After that I rebooted the phone and the 'Welcome screen' was back. It says the phone is installed correctly, you can use the phone etc. After that I have to choose a WiFi connection. And than the phone works again good. This happens everytime when I reboot the phone.
I also tried this without the backup on the phone, and when I rebooted the phone this time, it does not show the welcome screen. What could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
a few different things have fixed this issue in my shop before.
1) most commonly, a Hard reset fixes it. (Power and home for 15 seconds)
2) sometimes, when i replace the battery, and this goes away.
3) there is a row of components on the board, if these take any damage, it can cause issues with the battery. if the board doesnt recognize the battery when its off, it will reset all the setting on your device.
4) Forcing a fresh restore onto the device. manually downloading the iOS, and using the DFU mode to force it onto the phone can help this issue.
That being said, there has been times where i have been unable to fix this issue without a logic board replacement as well.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for your answer. But the phone works fine when I use it with a clean install, without the backup.
完成的
alrighty, then then that means your backup is corrupted.
完成的
添加一条评论
添加你的答案
Uas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 333
