跳转到主内容
Repair guides, manuals, and troubleshooting help for a wide variety of Nikon lenses.
Autocus wont work after rotating focus ring while AF
My sister was using my Nikon D3300 and "accidentally" rotated the focus ring of my Nikon 55-200 DX while it was set on AF. Im pretty sure I heard a noisy "clack" and now the aoutofocus wont work anymore; It doesnt even try to focus (you can hear a tiny noise but not a "focusing" noise).
Specific lens: Nikon 55-200mm 1:4-5.6G ED AFS DX VR
Any advice?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
On some lenses you can use the manual focus ring to override the autofocus while in AF mode, however it seems like this lens doesn't have that feature. When your sister rotated the focus ring, the autofocus motor was still connected to the focus assembly and she put forces on parts that weren't made to withstand those forces in that kind of way. Based on the noise you heard, it sounds like some plastic piece likely broke off inside of the lens, permanently disconnecting the autofocus motor from the focus assembly.
Based on what the lens is worth, taking it to a repair shop would likely not be worth it as you might be better off just buying a used one off of eBay. The other two options would be either accepting that you can only use the lens in manual focus mode, or attempting a repair yourself. Do note that if you were to continue to use the lens there is the possibility, if a piece did break inside the lens, that the piece could potentially migrate to other parts of the lens and cause other issues.
As far as repairing it yourself goes, if you already consider the lens to be a loss then there is at least not much harm you can do attempting a repair. I'd recommend seeing if you can find a disassembly guide or video online. If you can find one, you can partially disassemble your lens to try to find out what broke and if you can fix it or replace the part. Sometimes replacement parts for lenses can be a bit difficult to find though, depending on the lens.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gines Cirera Dona 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 328
