跳转到主内容
First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
71 个问题 查看全部
Transfer 3G Antenna To New Glass
First I am not sure I am referring to this antenna correctly. On step 18 on this page it refers to this antenna as the GPS antenna:
iPad 3G Front Panel Assembly Replacement
but on step 7 on this page:
3G 版iPad(初代)拆解
it sounds like it is referred to as the 3G antenna. Regardless I am trying to transfer the antenna pictured in step 7 on this page:
3G 版iPad(初代)拆解
I can get the antenna out from between the glass and the frame but without using a heat gun I see no way of getting the antenna back in the new glass (no mine did not come with the antenna, and no I did not get it at ifixit). I have tried placing the antenna in place but I get VERY poor 3G. I looks and sounds like this is do to how the antenna is supposed to use the frame as an antenna.
Does anybody have any experience with transferring the Apple antenna to a new frame that does already have an antenna?
Thanks.
iPad 3G图片
指南
3G 版iPad(初代)拆解
难度:
中等
iPad 3G Front Panel Assembly图片
指南
难度:
困难
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
andyboutte,
Yeah, that antennae is quite difficult. Unfortunately, it seems that the best way is to loosen the adhesive using a heat gun in order to preserve what seems to be some sort of NASA grade adhesive :)
It takes a lot of time and patience, so hang in there. And be careful with the heat gun. If you have it set too high or too close to your work area, you can accidently melt the plastic gasket attached to the digitizer glass. I usually leave mine at about 500 degrees.
这个答案有帮助吗?
得分 0
添加一条评论
Ok, it is a tough one. Because me digitizer was bad, I sacraficed it and pryed the antenna out. The glue is like alien snot. This worked fast and the digitizer was being thrown away anyway. Cheers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
andyboutte 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 2,098
